How to attach adhesive mount to phone
KathyJM
Member
I have bought a mount system to attach my phone to my bicycle. The mount sticks to the back of the phone or its case. However the instructions state it must be applied to a hard, rigid surface.
All the available cases/covers for my phone are either silicone or leather-ish. I don't want to stick the mount to the phone itself.
Any ideas? Is there maybe a sticker of some sort that will adhere to the case, that the mount will then attach to?
something like that will usually come with the mount. if none is provided, i would just use the case.....as long as the case is flat where the glue to the adhesive can stick to i think you should be fine.
The instructions specifically say it won't adhere to a silicone case.
