Hi guys,
I've had my Samsung Note 3 for years but recently having some issues with it so I think I'll just start again from scratch and hope this sorts out my issues. I essentially want to do the equivalent of reformatting a PC and reinstalling the OS.
A couple questions:
1) I currently have a custom firmware - the only reason is to get around the security settings of my old work (to access emails, you need to input password to unlock phone every single time). I'm not sure if my new work requires this for my emails - how do I check if this is the case or not?
2) If I don't need to get around the custom firmware for the above reason, I will go with the genuine firmware. Otherwise, I will need a custom firmware which allows me to apply a fix for the email security settings. I don't need any other custom features - I just need a firmware which is as light as possible. Suggestions?
3) I have over 1,100 contacts in my phone. I want to ensure I don't lose any. When I go to Contacts and Select "Contacts to Display" --> "Device" there are none - so I'm assuming that if I reinstall a new firmware, there are none on the device to be lost, and as long as I re-sync with Google/Samsung/Microsoft Exchange accounts, I won't lose any. Is this correct?
4) Is there anything I need to backup aside from contacts, images/videos etc?
5) My memory card is about 5 years old and sometimes plays up so I might get a new one just to be safe. What is the fastest version available, and what is the largest size you can use with a Note 3?
6) What is the process for doing a full wipe, and reinstalling a new firmware? I installed my current firmware years ago and have forgotten the process
Thanks a lot.
PS: Below are the details of my current firmware version etc:
A couple questions:
Thanks a lot.
