t0ast3d
If you find this helpful or think it would be helpful to others, tip it for a sticky!
Here's a little guide I put together for you to learn basic adb commands.
I'm posting this thread assuming you already have your SDK set up
^ I believe there is a sticky right below/above this thread on how to do so ^
With that said, let's dive right in!
1. Turn on ADB
Go to Menu > Settings > Applications > Development > USB Debugging
2. Running ADB
Open up command prompt and type your way to the directory you have your SDK in.
Mine is in C:\
So for example, mine would be: cd c:\AndroidSDK/tools
You are now in
3. Basic ADB commands
ADB push (sends files to your phone) -- adb push c:\example.apk /sdcard/example.apk
ADB pull (Receives files from your phone) -- adb pull /system/app/example.apk c:\example.apk
ADB install (installs application) -- adb install c:\example.apk
adb shell (Begins shell connection with phone)
adb reboot (reboots phone)
adb reboot recovery (reboots phone into recovery)
adb reboot bootloader (reboots the phone into bootloader/the white screen)
adb remount (remounts the system)
4. Commands to run while in ADB Shell
cd (changes directories) -- cd /system/app
ls (lists all files in the directory) -- cd /system/app
rm (removes files) -- rm /system/app/example.apk
cp (copies files) similar to cat -- cp /system/app/example.apk /sdcard/example.apk
cat (copies files) -- cat /system/app/example.apk > /sdcard/example.apk
exit (exits shell) -- exit
Might add a little more later if requested.
Hope you learned something!
1. Turn on ADB
2. Running ADB
Mine is in C:\
You are now in
