Apps How to center align Fragments
krishnan
Hi
Please see the codelet that we are using to center align the player.
I would appreciate any kind of pointers to fix the issue.
Layout Structure:-
1) I have a list view to display a movie title/name
2) I have a fragment to display the movie
Iam are trying to center align the fragment by setting its gravity.
// Layout files
HTML:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:id="@+id/root"
    android:orientation="horizontal" android:layout_width="fill_parent"
    android:layout_height="match_parent">
    <LinearLayout android:id="@+id/listLayout" android:layout_width="140dip" android:layout_height="match_parent">
    <ListView
            android:id="@+id/movies_list"
            android:layout_height="match_parent" />
     </LinearLayout>
    <LinearLayout android:id="@+id/fragmentLayout"
    android:orientation="horizontal" android:layout_width="wrap_content"
    android:layout_height="match_parent" android:gravity="center">
    <fragment class="com.application.PlayerFragment"
        android:id="@+id/titles" android:layout_width="wrap_content"
        android:layout_height="match_parent" android:layout_gravity="center_vertical|center_horizontal"/>
        </LinearLayout>
</LinearLayout>
Code:
public class PlayerFragment extends Fragment implements SurfaceHolder.Callback {
static SurfaceView surfaceView;
SurfaceHolder mSurfaceHolder01;
onCreate()
              surfaceView = new SurfaceView(getActivity().getApplicationContext());
        mSurfaceHolder01 = surfaceView.getHolder();
        mSurfaceHolder01.addCallback(this);
        mSurfaceHolder01.setType(SurfaceHolder.SURFACE_TYPE_NORMAL);
## Here is surface change callback I am trying to center align the fragment when
public void surfaceChanged(SurfaceHolder surfaceholder, int format, int w, int h) {
               // Not working/ No change on Fragment
                 LinearLayout fragmentLayout = (LinearLayout)getActivity().findViewById(R.id.fragmentLayout);
        //LinearLayout linearLayout = (LinearLayout)getActivity().findViewById(R.id.fragmentLayout);
        //((LinearLayout.LayoutParams)linearLayout.getLayoutParams()).gravity = Gravity.RIGHT;
                 // It working on the list view/
                 //LinearLayout linearLayoutMovie = (LinearLayout)getActivity().findViewById(R.id.listLayout);
                 //linearLayoutMovie.setVisibility(View.GONE);
