How to charge a Xiaomi Poco M4 Pro for the first time?
Biffos
How should one charge a smartphone generally / Xiaomi Poco M4 Pro for the first time(s) (to avoid losing performance, respectively to get the best performance of the battery pack)?
Or does it not matter at all? To care about charging is extremely uncomfortable, I would think. But losing capacity / performance of the battery pack would not be very good either.
There's no method in my opinion of how to charge cellphone batteries. You just plug it in and let it fully charge. Batteries tend to last 3-4 years,. You will then start to see your battery life start to drain faster after that. For me I get phones every 2-3years so I never really worry about my battery life.
Just keep in mind that every time you charge the phone, you lose a very tiny fraction of battery life.
Many thanks, also for the links.
Well, yes, that is right of course, I actually have absolutely no desire to deal with something like that. For example, especially if a battery should be charged / discharged now (respectively to wait until the battery completely is discharged), to check the charge status all the time etc.
Then I'll rather do it like you and I will buy a new phone every three or four years. And for that, the effort of getting all your own settings (at least as large a part of them as possible) / data to the new one.
