My music keeps skipping randomly, I don't think it is the player since this is happening on multiple apps.
What is the best way for me to verify my SD card is working as it should?
Nothing. Running check disk, you will just see a loading bar as the computer checks for errors. Then it will ask you if you want to fix the errors. It may delete some files associated with the errors.
Personally, I think you're card is about to bite the dust. Just backup everythinh you have on it.
Tried it on 2 different cards had to use command prompt as UI says card was locked (even though it isn't) both times it runs for 4 hours and times out.
