Root How to clear Superuser Permissions Log?
tsanchai
After rooted my Galaxy S, everything work fine except one problem that I need help.
Under Superuser Permissions, I have seen a very long log, and there is no way to delete or celar them off my Galaxy s. For sure it will take up storage memory. No clear log option in Settings of Superuser Permission 2.3.4.
Any friend here can tell me how can I delete or clear this Superuser log? So that it won't eat up my storage space
Thank for advise and solutio n in advance
hey I just have the same problems (it's just annoying logs) sure Snapper is also correct, but if you still wanted to do it, try this :
Make sure the superuser app is running (tap it and back)
Go to Setting/Application/manage application/running app.
Scroll down, tap superuser, choose clear data.
remember this will clear up all granted app saved, dunno if its running on Eclair, but froyo will surely do. Lemme me know if its not working
