windranger
I need Android to connect to both WiFi and the 4G Network in the same time.
As known, the default setting makes Android disconnect from the network once it connects to WiFi,
therefore it can't connect to both simultaneously.
There is an app in the Google app store called Speedify which does this:
speedify.com
But I would prefer to do it myself if possible. I checked on the net and some suggest to edit the 'ConnectivityServices.java' file;
however, I couldn't find yet the solution that works for sure.
Some suggest some editings in the ConnectivityServices.java file, but I couldn't find yet the solution that works for sure.
I would appreciate any help on how to achieve this.
How to Use WiFi and Data at the Same Time on Android - Speedify
Contrary to popular belief, it is possible to use both WiFi and mobile data at the same time on your Android device. Just connect to both networks and use Speedify to combine them.
