how about someone get a walkthrough for people who doesn't know or really understand for the more tech-enabled users here rather then just showing us videos and pictures rubbing it in my face, heh i don't mean to be mean but don't you all think it's kinda rude that they won't sure if it's "Soooo easy" XD not trying to be mean but show us please. a text walk through would be fine just show us if there's apps or if there's something needed? was it done fully wireless or otherwise. thanks sorry for the angry letter XD
1. You have to use a sony ps3 controller for 100% success.
2. You have to be rooted if you do not have a dock.
3. Your beter off rotted anyway using the sixaxis app from the market here:
https://play.google.com/store/apps/details?id=com.dancingpixelstudios.sixaxiscontroller&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5kYW5jaW5ncGl4ZWxzdHVkaW9zLnNpeGF4aXNjb250cm9sbGVyIl0.
4. you need to download the free program from dancing pixels on their website to change the bluetooth address on the controller to match the bluetooth address on your tablet in Settings> About Tablet> Status and scroll down. Make sure you have bluetooth turned on before you look for this.
5. follow the directions of the program and enter the bluetooth address from your tablet into the program on your computer and save it to the controller.
6. start app on tablet and push ps logo on controller. The controller should turn off when you end the app or turn off bluetooth.
IF YOU CAN GET YOUR HANDS ON A DOCK OR CAN GET THE USB ADAPTER YOU DO NOT NEED TO ROOT NOR NEED THIS SIX-AXIS APP.
For the sake of argument and can get access to either a dock or usb adaptor (tf101 usb adapter supposedly works)
Use the USB cable hard lined to the dock/tablet and the controller should be found. Attempt to play a game and use the controller. After approx 5 minutes end your game and turn on bluetooth. Disconnect your controller from USB hardline and attempt to turn it on wireless. The controller should be found by the tablet.
WARNING: When you are done with the controller the tablet will not turn it off by this method. If you did not originally set the controller to turn off in a set time from being idle on a Playstation 3 your controller will continue to blink until the controllers battery is dead. Not that this is the end of the world but more an inconvience, I have my controllers set to turn off in 10 minutes when idle.
Worst case situation:
get a dock/USB adaptor from a retailer and return it when done.
get a PS3 from walmart to set time out feature in the controller (Only a PS3 can write this to the controller from what I understand) and then return it when done.
follow the procedure above
_Lostsorrow
thanks dude finally someone gave us a walkthrough, i'm pretty sure it means alot to the users that didn't catch on how to do it, besides myself to get the info. i'm not planning on rotting my tablet while i do like the idea... i don't trust my skills, maybe someone else can find this more useful. in anycase thanks so much for the help ^_^
That is the one saving grace of the Thrive, since has a full USB port. Works great with gamepads.
