how to create and deploy webservice in android
predeeps
i need to create and deploy webservice in android to export my app data on demand by other systems (likely .net). Help if u know how to do it....:confused:
thanks in advance... bye...;);););););):):):):):);););););)
Welcome aboard. Android Forums is a friendly place for discussion, learning and help.
Nice of you to stop in to join us. Here are links to our Android-Phones and Android-Tablets forum. Choose the device you have - find your model _check into your device's area of support...where you'll find some interesting info, hints, tips & tricks on your device. If you need any help navigating the site, just give one of us Guides a shout!
Enjoy! :)
Hello,
I am writing code for android using java "Calculator". I am using the approach of MVC "Model View Controller" I have done everything but there is one thing I could not do in The Model class I need some how to use StringBuilder with integer. I believe I should use for example Log.d or Log.i but I could not make it. plz help is needed.
Just keep in mind I am using Multithreading for this application
