Hello!
I want to create folder in menu tu put there programs what I use not often.
Its annoying when I have 8 desktops.
P.s. How to add location where to put installed programs from store?
download this: https://play.google.com/store/apps/...1bGwsMSwxLDEsImNvbS5nYXUuZ28ubGF1bmNoZXJleCJdHello!
I have the LG G3 and its very simple. You need to go to options (this could be on the bottom ribbon or on the top right like mine is) click on sort by and chose customise. Once you've done that go back to options and select edit/uninstall. Long press on the app you want to make a folder with and hover it above another one to be included in that folder. Hope this helps. Happy droidingHello!
