kumaranil13k
Question How to cure Battery draining and lagging problem
I have lyf water 7 ls-5504 mobile it's been rooted through super user to use link2sd and link apps. But before rooting it's have huge proble of draining battery it's battery drains 25% within if screen off to 10-15min from 100% to 75% very fast. One day it got battery calibration problem to it showed 0% and still it was working... Then I went to sevice center and they formatted and installed th android 5.11 stock rom again they electrically tested said battery is okay but software problem or may be software draining it.
As I googled and founded that some softwares setting consumes battery and to find them and kill or.force.stop.them and to cha he settings... Which switch off did ie. Developer option> windows animation scale / transaction animation scale/ animator duration scale
developer option drawing option
This option and GPU rendering I turned off and Bluetooth WiFi off and background process limit to 2 in setting developer options which reduced the battery draing in off screen but still while using its
draining to fast in compared to same company other model with same 3000mh battery.
So after rooting I installed greenify and accu battery to solve the battery charging or draining problem still it's same.
I tried to hybernate through greenify app one or two apps which are silently memory resident but I can't restrict system (google.play services) so I screenshot the developer option process stats to refer you apps running in memory
Devloper option process stats screenshot
Following is screenshot of battery apps usage of android 5.1.1 native
settings battery statistics screenshot
From below screenshots of accubattery app photo I have given to give reference how much mh or percentage battery is consumed in charging and discharging . If any expert can find the reson. Or app of its draining battery fastly and second phone hangs lags and respond to late and stuck in browsing many times and many time I have to close all running apps and restart them again. Is it due to rooting or.permissoon apps or link2sd apps or due to accubattery or greenify. As link2sd accubattery or greenify is no where in process stats ... I had not linked or moved system apps or random used apps to external sd card..
Now if u can help or advice.me how to redicate or troubleshoot or find the app which is draining the battery or hanging or lagging . The phone....any more reports or details required for your refrence I can send screenshot ...any opinion advice to solve help will be welcomed
Following is accubattery aps stats infor.of battery discharges and charging stats
accubattery apps
charging stats screenshot
battery usage stats screenshot
discharging usage screenshot
discharge speed apps wise usage
discharge speed screenshot
apps charge status
From above photo of accu battery apps monitoring I have given to give reference how much mh or percentage battery is consumed in charging and discharging . If any expert can find the reson. Or app of its draining battery fastly and second phone hangs lags and respond to late and stuck in browsing many times and many time I have to close all running apps and restart them again. Is it due to rooting or.permissoon apps or link2sd apps or due to accubattery or greenify. As link2sd accubattery or greenify is no where in process stats ... I had not linked or moved system apps or random used apps to external sd card..
accubattery apps
apps charge status
