spiz
Android Expert
Samsung Vibrant Car Mount/Home Dock
The total cost of this can vary, but it's still inexpensive. If you are like me and like sleek and not bulky, then this is for you.
Disclaimer: You take full responsibility of anything you do to your phone listed in this guide.
** Note: The desk mounting portion of this only works if you have a glass/smooth plastic surface **
Materials/Parts
- Samsung Vibrant
- Extra back cover OR Gel Case from TMobile ($16.99)
- Garmin Suction Cup Mount ($14.23 +shipping from Amazon.com)
Found here: Amazon.com: Garmin Suction Cup Mount: Electronics - Something that can cut hard plastic (Gardening clippers work fine)
- J-B Weld ($5 at most stores)
So the total cost of the parts if you decide to use the Gel Case from TMobile is approximately $40. If you're like me and don't need one of the extra back covers that your phone came with, then that will save you 17 bucks, bringing the total to $23. Not bad for how amazing this works.
Steps:
1. Take your Garmin Suction Cup Mount apart by removing the suction part from the clip (just pull it off).
2. Take something that can cut plastic. I used some gardening clippers, but you could choose to use a utility knife, small saw, etc...
3. Cut the parts as shown below.
4. Then clean the two surfaces that you'll be applying J-B Weld. Any oils can cause less strength in the weld. So clean off the extra back cover or the gel case, whichever you decide to use.
5. Apply J-B Weld as shown below.
6. Quickly place this onto your desired location on the extra back cover (or gel case) and hold firmly for approximately a minute. The weld will form and be very hard within 4 minutes, so be somewhat quick, but also careful. Picture of mine below:
7. That's it! I let mine sit for an hour or so before even testing, but at that point, it was plenty strong enough.
This can now mount to your windshield or a glass/smooth plastic or metal desk/table at home. With the brightness of this screen, sunlight is never an issue when mounted on the windshield. Be creative and put it wherever you want. More pictures below!
Thanks for checking out this guide. I hope it helps someone or at least sparks some creativity to come up with something similar. Later!
