girolez Often Off Piste Nov 20, 2013 #2 Hi You cannot remove/uninstall them without rooting your phone, but if you are on a recent version of android you can disable them menu manage applications scroll to the one in question & select it press disable (disabled apps are listed at the bottom under the "all" tab in manage apps - you can enable them from there) Roger
