slicksandwich14
As the topic title says, I sent text messages from my LG-P500h android phone while my phone is currently deactivated.
I see the "sent at (12:00pm or w.e)" as if it were a normal text, and I don't know if the reciever got the text or not. I figure that if a phone is deactivated it would logically mean you can't sent a text, right?
In any case, if my phone is reactivated in a few months time (which it very well may be), will they recieve the text the very moment my phone is reactivated? And if so, how can I prevent the messages from being sent?
I've heard you can do a factory data reset to stop the messages from being sent, or you can just manually delete the texts but will that stop them from being sent upon reactivation?
Answer as soon as possible!
Thanks
Thanks
