seriously do i have to wait for the rest of my life to get an answer? iam not beeing rude or anything. as a matter fact i thanks al the ones that tryed answering my question.... but its been more then a month since i posted this question and nooen has anything on how to put this phone on DIAG mode or what ever do that need to do..
I know its several months later... BUT..
I was having some trouble with this too.
Here is the solution:
1. (If you already have your MSL/SPC, skip this step)
You have to have your MSL/SPC 6 digit code. This is not easy to come by since you can't connect your Intercept as a modem to read it with Cdma Workshop or QPST. You could call VM and ask, but I doubt they'll give it to you.
However there is a workaround:
Download this APK:
(3 w's).mediafire.(com)/?jjjynwp2y65ephj
It's a little app called ConnectBot. Once installed, in the lower left hand corner, where it says SSH, change that to "Local".. Then put anything in the text box you want.
When the command prompt comes up, type the command "getprop ril.MSL" and hit enter.
This should give you your MSL/SPC 6 digit code!
2. Dial ##PORT#, enter your MSL/SPC, and make sure both options are set to "modem" and not "pda"
3. You are gonna need additional drivers to access the phone as a modem. On Windows 7, it tries to install, then prompts you to download "Samsung PC Studio 3"
DO NOT INSTALL The one it suggests! Instead install this one:
(3 w's).mediafire.(com)/?k7pxzu3uc03nepn
This program will install the drivers you need.
Any questions just ask,
Kev
