vincent john
Howwwwww???
Use the device in a warmer area.
You can't disable that warning because it's just telling you that the safety feature is being activated. Forcefully charging a battery whose temperature is too low is a good way to make it explode.No. Because i already mount it inside my car. And if that notification pops up it stops charging thats why needed to disable. Is it possible? Anyone there?
Battery temperature too LOW??? What app is giving you that popup? I have never heard of a battery being too cold...![]()
Is the phone and car temperature at below 0 degrees C? Because basically you can't charge lipo batteries at below freezing temperatures, and the phone might be telling you that. Once the car is running and things have warmed up, it will be OK.
Yup were just -17•c here in our country..
https://forum.xda-developers.com/galaxy-s3/themes-apps/mod-disable-low-battery-battery-t1810772
I have read that link but i dont know how to execute. Do you guys know?
Read that again. It makes no difference. Following the instructions in there would just remove the notification, but the phone STILL WILL NOT CHARGE.https://forum.xda-developers.com/galaxy-s3/themes-apps/mod-disable-low-battery-battery-t1810772
I have read that link but i dont know how to execute. Theres a code to disable it. Do you guys know?
what phone do you have? have you tried rebooting the phone?Last week we finally had some cold weather here in Helsinki, and now the notification seems to on permanently. No it's not that cold in my apartment, and my phone charges just fine.
