Help How to disable blinking notification icon in peek display?
I cracked the screen on my phone (moto g power 2021) and bought the the exact same model to replace it. Both are running the same Android 11 build.
On the Peek Display, the old phone shows a simple icon for notifications, e.g. new email. The new phone shows a flashing icon for notifications with "Tap and hold" above it. (See photos below.)
The flashing/blinking icon is annoying, but I can't find a setting to make the Peek Display use a plain non-flashing icon like my old phone.
How do I configure Peek Display notification to use just the icon and not the blinking/flashing icon with "Tap and hold" above it?
Have you tried it with Safe Reply off, I'm sure you have.
I have an older E6 elsewhere but also have you tried the Moto or *Device Help app (if there) for the setting.
Also, though the same model, some settings or the Moto or *Help (iirc) app may have updated in the newer one. You can compare the version in Settings - Apps.
Not much help, but hopefully someone with a Moto will respond.
*I see the actual app is called Device Help on my E6 (no Peek Display)
