how to disable the low battery popup
chrcol
this starts popping up every 5 minutes when the battery is below 25% very annoying, how to disable it? otherwise I have to charge when only 75% of battery used.
This doesnt happen to me (if you have rooted; it can bring problems), i get connect the charger message on the LOCK screen ONLY (when battery level is below 20%), and i dont get any pop up until below 15% (and thats on 1 pop up) and the final one below 5%, so i only get 2 pop up messages telling me battery is low (and they are needed so you know you have to charge to phone when on 5%)
Order a free giffgaff sim and get
I've had these annoying popups exactly the same way, right from the moment I had the phone. I guess there's no way to avoid them. You don't have to charge right away though, you can ignore it for quite a while. When it gets more "critical", you'll get a notification sound as well. That's the time to listen to it and charge the phone.
