I don't have the option "Software update" under Settings/About Phone.Go to Settings/About Phone/Software update/Update. Make sure your device is connected via wi-fi as any update will be quite large.
Yes it's locked, T-Mobile UK. Kies tells me I'm on the latest firmware which is fine since the jelly bean update hasnt been released for the phone by T-Mobile in the UK yet. The phone has not been rooted.That's odd and I don't know why you don't have the option available.
Is you phone rooted/custom Rom?
What does Kies say when you try it?
Edit: Is your phone carrier locked? If so, what carrier are you using?
Thanks.
Some carriers remove the OTA feature on their branded firmware
