A
Android Question
Guest
I want to edit in android framework and test the android OS after editing.
for example: I want to edit in java code then convert these java files to format suitable to install it on Virtual machine VM.
or I want to access as root user on Linux then do i can edit in framework after that or not
and If I can edit. which commands to edit in the framework
