Help How to Enable Data Connection, 3G/2G/GSM after Disable (Samsung Galaxy Apollo) ?
Hi,
I have Samsung Galaxy apollo, I have disabled the Data connection because of small battery life. Now I want to Enble the data connection for using 3G/internet outside WIfi range.
I have used to disabled the Data connection as below way..
# Dial *#*#4636#*#* to open
Hi,
I have got the solution. I have reset the phone on factory mode. All the application have installed again. Then working perfectly.
Actually phone battery life span is very short (3-4 hrs) without WiFi/ GPS/ Account & Sync/ No major application / phone call 30 min max in 3-4 hrs time span.
Now I have installed the Advance Task killer & APN application (for Enable/Disable Data Connection, 3G/2G/GSM) for increase the battery life. let see how much battery life will increase.
If anybody also facing the same battery problem & they have any idea for increase the battery life then let me know.
Regards
Susheel
Hi,
Regards
Susheel
Yeah I think 3G drains the battery quickly. I'm trying to find a way that I can disable 3G and turn on 2G/Edge?
Hi friends,
Though who are struggling with the Low battery life for Samsung galaxy Apollo phone good news for them.
I brought this phone few days before. since that day I was facing the low battery problem hardly 3-4 hrs battery life. I have tried so many ways to increase the battery life by installing many applications. But No result. Finally I have got good & easy solution of this I have installed the 'Quick Setting' application with 'Advance task killer'. Its a free on android site. By this I can Stop/Start the 3G/2G data, Auto Sync Data, Wifi,GPS, blue tooth, Sound, Brightness and Ringer/vibrator if not in use. If need then switch ON after that switch off.
As per my observation. In morning 8:00 a.m. my phone battery was 100%. in whole day I have use min 75 Min Voice call, Media player mp3 songs played approx 1.5 hrs, 45 min approx Internet mail check & download some software also by 3G/Data. Now 10:00 p.m. my phone have 70% battery life. Previously in 4 hrs my phone used to dead/switch Off automatically because of low battery.
Now when I need Internet I switch ON Mobile Data 3G or WiFi / AutoSyncData by one touch toggle button switch of 'Quick Setting' application. After the use I used to switch off.
Dramatically my phone battery life increase 3 times then before (more then 12 hrs).
If anybody is also facing the battery problem then follow my way.
Regards
susheel
Settings.....Wireless and Network.....Mobile Networks.....then you see 4 options.
Click on use only 2g networks.
Ang x
Has anybody found a decent app that switches off the 3G/Edge but leaves the MMS setting intact (O2 PAYG)?
I was using APNOfOff by CurveFish but today realised that, despite me saying "enable MMS" when switched off, I was not successfully sending or receiving any MMS messages.
Hello,
you can try app Internet OnOff Free application from android market
https://market.android.com/details?id=internetOnOffFree.vv.android.development.com
where you can choose if you want MMS enabled or disabled
