Help How to export contacts from X10 to iPhone 3G??
One way is to create google account...then in the phone menu, goto Sync and choose to sync with your google account.
Then on new phone....go to sync...login to your gmail account.
Another way....open contacts....push left button on the phone....chose Backup...and chose the SIM card....then it will copy contacts to the SIM.
Then manually take the SIM out....put in new phone...left button...import contacts...chose SIM contacts..then it will copy them to memory....then take out SIM...put back in old phone....
I tried the SIM method but a SIM card can only hold a limited amount of contats.
I'll try the google method.
thanks
