http://www.mediafire.com/?l9vaai8eurzw59p you extract make a folder go to kdz_en.exe make sure phones in download mode holding vol up and plugging usb into phone and pc select emergency mode.in the browse kdz field find your kdz file and then press the button to start the process. this is the same method for all the lg phones to my knowledge.i used to give advice for the f6,still do but i moved on to another phone now.thisll get you hooked up though gl
kdz is always an auto unbricker,as long as your pc still recognizes your phone whitch it should in download mode your good
