How to figure out DPI Sideloading
BadBuddah
Hi how to you figure out what's ok DPI to Side load......
If My DPI on phone is 294 ppi , screen density 360 dpi xhdpi, 693dp x 320dp
Instruction sets arm64-v8a armeabi-v7a armeabi
can i install this apk? will it work ok thanks.
(arm-v7a) (280-320dpi) (Android 8.0+)
is this for develop purposes?
cuz we do have a developers forum.
no
not unless you are developing an app or something like that. what apk are we talking about?
It's google message app , But the hardware check i did as above comes up 360 and 320 so not sure if i need 360. Or the 280, 320dpi is fine?
never heard that google messages need certain dpi in order for it to work. dpi (dots per square inch) in terms of phones should be in ppi (pixels per square inch) anyways. should be fine in most phones.
what phone do you have? why are you looking for an apk for it? it should be in the play store.
Yes on there just wanted the Beta :rolleyes: ....... seems to be working ok so far. But i just didn't want to stuff the phone as I"m not used to sideloading
