Apps how to find a gps Coordinate on goole map
hno2005
HI
i want to find a gpls Coordinate and locate it on my google map. I've this code but it's not working :
Code:
	private GoogleMap map;
	private final LatLng location =  new LatLng(310901,512113);
	@Override
		setContentView(R.layout.activity_main);
		map=((MapFragment) getFragmentManager().findFragmentById(R.id.map)).getMap();
	public void onclick_btn1(View v){
		CameraUpdate update= CameraUpdateFactory.newLatLng(location);
		map.animateCamera(update);
I've this coordinate and it've tested it on google :
E512113 N310901
How can I tell google to find this location ?
Thanks so much
I've never written code to do what you're doing, but lat/lon coordinates are given as + and - numbers, not as E and W. That may be your problem.
West (of the Greenwich meridian) is negative, east is positive. North of the equator is positive, south of it is negative. Try 512113 310901. (It looks to be somewhere in the Middle East, roughly.)
thanks for you help, I could find E512113 N310901 on my gps app and it's correct .
I think this is another type of coordinate .
Do you know how can I convert it or how can I change google map type to this type ?
