Hi guys I was triying to do the S-OFF for my Htc 4g V after I did the Rooting and my Htc when Blank and the Goes into a infinte Loop where the Htc Logo with the White background.
and It never turns on
So any help will be greatly appreciated
Try pulling the battery, then putting it back, hold vol down and power to get into the boot loader from which you can get into recovery, then I would wipe, install a sense stock room and trying s off again, if that doesn't work try plugging into computer and using adb commands posted in rooting guide to get into recovery and flashing Rom
You were attempting s-off when it rebooted?
Have you read through this thread, might be helpful
http://androidforums.com/evo-v-4g-all-things-root/595469-help-screwed-up-s-off.html
Well I downloaded the controlbear 0.7 beta.good to hear, what do you need help with? S-off?
Also, what did you use for the wire?
are you using the "windows (for virgin mobile evo v only)" version?
