How to fix android WiFi error?
  • Thread starter Thread starter Jaward
  • Start date Start date
J
Jaward
Guest
I have a Mobicel Titan, it runs android 2.3.7 Gingerbread.
When I turn the WiFi on it says "scanning" continuously and then error.
I have tried factory data reset, WiFix and #*#*526#*#*, but nothing works please help.
Are you sure that you're within a b, g or n wifi signal? If you are, I'd bring it back. It could be a bad wifi radio or bad wifi firmware (neither of which you can fix without voiding the warranty - and possibly bricking the phone).
