Root How to Fix Bootlop by setting CPU too high?
Bard
Android Expert
Hello & Sorry if this was asked before.
While overcloking CPU with Rom Toolbox, I forgot to uncheck 'Apply on Boot' option. Since I set it up too high (2096...) it's keep rebooting over and over.
Last time when I did this, my phone was able to last like 10 seconds, so after multiple trials I was able to open Rom Toolbox and quickly lower CPU.
This time, it last much shorter :( It reboots before I go to the Rom Toolbox CPU setting.
Luckily I have Clockwork Recovery installed, If wipe personal data or cache, would I be able to get out from infinite loop?
Your help will be very appreciated.
Thank you.
Thank you.
if u have profiles set just plug ur phone in then turn it on
