How to fix camera resolution inside specific app
behrprofl
Member
I have a Samsung Galaxy Note 10+ and there is a camera feature inside the "MyNBA2k22" app. When I try to use the feature that uses the camera, it is long and thin instead of the right dimensions.
Is there a way to force the camera in the app to be a specific resolution or any other way to fix this?? I attached pictures of the normal camera and then the camera inside the app.
other than changing the aspect ratio, not sure there is a setting with in the camera app that came with the phone. is this for something like you avatar within NBA2K? can't you just use a photo on your phone? maybe you can edit a photo to the right ratio that will work within the app.
