what flashlight app are you using?I accidentally dropped my Stylo 4 yesterday and my flashlight turned blue, and I can't get it back to the original light. Can someone please tell me if there's a way to fix this issue?
Have you restarted your phone since the accident? If this blue light issue is just a one-off glitch, restarting might solve the problem.
But more details might reveal more about what's going on. Have you also done any tests like using the camera app to see if the light is still discolored? Typically it's a pretty balanced white light but when you're stating it's now blue could you explain more about this? Is it now a deeper, more saturated blue or just a white light with a bluish tinge?
Offhand, since the phone was dropped if restarting doesn't help than it's less likely to be software issue and more likely to be a hardware issue -- if it's something like a solder joint was damaged from the impact that could be a much more involved fix (replacing the logic board) but if the camera module is modular there's a possibility it might only involve replacing just the camera module (but that is a big 'if' as most manufactures do not make individual components modular and replaceable, and instead just solder them directly onto the main logic board).
Was your phone in a case when it was dropped? How far did it fall? Was it a solid surface or something like a carpeted floor?
