Root How to fix GPS
I am using drdogautam's latest ROM A75 Stock Updated 2.3.5.
I like this rom very much in terms of battery life and better performance.
However, I could not get access of GPS. Can any body look in to this matter?
Hay Developers...
Please help me to start GPS in this ROM. It is not working.
Can anybody tell me setting or GPS fix to resolve this issue.
Hay Developers...
Enable all the things in GPS and also enable wifi also then download EPO file and after that try to get lock of GPS you will get it then.
Dear Shahabazasbhai.
I have enable all the things in GPS and downloaded EPO data file but no result. still GPS not started. I have also downloaded GPS fix from google market but could not successeded.
Did you tried of getting GPS lock from engineering mode?
Sorry for late reply. I was away for few days.
How to access engineering mode to get GPS unlock. Please also give information for settings to unlock GPS step by step.
In Engg Mode go to the MTK section and then Location and then Location based settings and then GPS section there you will have to enable EPO download and then try to get the Lock via YGPS.
Dear shahabhazas
How to access Engg mode? I have tried this system *#*#3646633#*#* but it wont allow me to get inside the Engg mode... Please help me for another way. My GPS still not working
Use Holo Launcher long press on home screen pop up opens and from pop select activity and in activity select engg mode then you will get shortcut on screen of engg mode from there you can access it.
Thanks now able to access Engg Mode.
However, I can not fined MTK section and then Location and then Location based settings
below are the menu
01. battery log
02. Touch Screen
03. GPRS
04. Audio
05. Camera
06. WIFI
07. Bluetooth
08. Networkinfo
09. Autoanswer
10. YGPS
11. AGPS
12. EPO
13. Video Telephony
14. Display
15. Memory
16. IO
17. Power
18. Baseband
19. FM Receiver
20. SIM Lock
21. SystemLog
22. De-Sense
23. CPU Freq Test
24. Bandmode
