Help How to fix the Freeze Problem?
thejaum
Hello guys, i Have a LG GW620 Eve and i see thats is a frequently problem
with this device, The Freeze Screen,Nothing Show on the Screen... The Buttons Work and the Touch Work.
Once in a while the Screen back to normal, But is only a question of time, He back Freeze and the screen goes CRAZY :confused: !...
I think if ALL The LG GW620 got this problem, Cause if do, IS A PROBLEM WITH THIS DEVICE :mad:!!!!
Please Someone know how to Fix this ?
Thanks and i'm so sry for the english hehe... :D
Welcome to the forums!
Sorry for your troubles. As this is an issue specific to the Eve, I moved your post over here to the Eve support section, where others with your phone can give feedback.
Ohhh i'm so sorry if i posted in the wrong section is cause i'm really crazy about this trouble :D, But thanks for you have moved to the right Section.
I'll wait for a solution :)
turn on a heater or put your phone in the oven for a few minutes....just kidding :)
there are a few things you can try:
take out the battery and sim card for a few minutes then put it back in, do this say every week, think about leaving your pc on for a cuple of days and see if its sytem does not give hasles, same concept.
Then if that does not work....try a factory reset.
Is there a specific activity you did when it started freezing ?
Thanks for your answer Man :D
Not rly, In Fact now he is Freezeeeed, How i say, He are TOTALY FREEZED(I don't know if this exist kk) Now the Screen are ever black, Don't display,No MORE!
I'll try take off the batery for a day and see if something happens, A factory Reset now is IMPOSSIBLE, He turn on already with the screen black, so i can't do a factory reset
