Root how to flash a rom
Thatdad
Android Expert
So I want to flash a rom, but I reaaaallllyyy don't have any idea what I'm doing at all.
Can someone explain to me step by step how to do this?
From backing up my Huawei Premia correctly, to the actual flashing of the Rom safely?
Sorry I'm extremely noobish with this stuff.
download the rom you want, and place it somewhere on your external sd card
boot into cwm recovery, and select "backup to external sdcard.
select "wipe data/factory reset".
select "install zip from sdcard"
select "choose zip from external sd card"
choose the rom you downloaded.
select "yes"
thats it.
make sure you read the ops instructions on flashing their rom for whichever one you choose
