monkeytools
Do This At Your OWN Risk.
Ok I figured I would make this so people can update to M140. If you have Gnm recovery or root. I have made a new stock m130 rom. That has a pure stock boot.img. I am also posting the boot.img by its self. For those that have root without gnm recovery, but have a moded bootimg.
First this is for root with moded boot.img. No gnm recovery {this means you have stock recovery on phone}.
Make sure you have all stock apps on phone {this means all the apps that the phone came with from Verizon}.
Then download my stock boot.img will be in post later.
Then download my multi tool. unzip multi tool any where. put boot.img in the multi tool file. note the stock boot.img that comes with the multi tool is moded and will not work. then run multi tool.bat. select option 2. And let it flash the boot.img. Then you can let it reboot. Then you can update phone.
Note when you update you may lose root.
Now for those that have gnm recovery.
first do a factory reset and wipe cache. then install my new stock m130 rom will be posted later in the thread. let it reboot. then download my multi tool, unzip, take stock recovery.img from folder and place in folder that has the multi tool.bat in it. then run multi tool.bat. select 1 and let it flash. then it should reboot to stock recovery. the stock should have the triangle with the android guy. when you get to that screen on your phone pull battery. then boot phone normally. then update phone.
Ok now on m140 root is the same as m130.
Go here and follow root guide.
M130 Rooted
go here for multi tool. http://androidforums.com/commando-all-things-root/717534-multi-tool-oneclick-installer-root.html
links
Stock boot.img:Dev-Host - boot.img - The Ultimate Free File Hosting / File Sharing Service
Stock Rom:Dev-Host - casio_stock_rom.zip - The Ultimate Free File Hosting / File Sharing Service
links
