Help How to get alert when phone is fully charged
You can use a third-party app such as GSAM battery monitor to set an alert for when your device is fully charged. This is probably your best bet, since I don't think your device has an alert for that built in. Let us know if you have any questions on how to set it up :)
Thanks again, Guitar20. (I just responded to your reply to my other query).
I downloaded this app, and the monitoring features are pretty impressive. Not sure I need all that detail -- especially if the app itself is using a lot of juice. When I was checking it out, I think it said it was accounting for 2.5% of my power usage. So here's my question: Is this app always draining juice from my battery, or only when I open the app?
Thanks.
The app monitors in the background, so it's always sipping a little bit of battery. I've found it to be more a benefit than an not, catching apps that are using 20 or more percent battery or going crazy in exchange for it's 2 percent or so of usage. So it's a bit of a trade off I suppose.
