Root How to get LG Volt stock rom?
jacmic22
Idk if this is in the correct section if not then its completely my fault
Anyways i wanted to address that after i had a recent update on lg volt i cant root with towelroot
Is there any way to bypass this? Ik from the get go i wasnt supposed to update but i did this time bk i was curious i thought there were new features but its just a patch
Is there any way i can possibly get at least a stock rom so that i can downgrade and root again thanks in advance
Start here
http://androidforums.com/index.php?threads/874943/ The "so you upgraded to z4 and lost root" guide.
