Help How to get non cropped wallpapers?
EarlZ
I had a lot of wallpapers that worked properly with the samsung wave and now i just got my SGS all of my wallpapers are cropped, i there a special setting for this ?
Not sure to understand what you mean.
In order to use a pic as a wallpaper, it has to be cropped to fit the screen size,
Do you mean that you tried to import your Wave wallpapers to the GS?
In that case, it might not work, the size of the wallpapers might not be the same (just guessing here).
nope.. thats the way it is in all firmwares.. just tap and drag the borders to resize and select the whole pic..
Was able to increase the border size but it still does not select the whole picture.. is there like a 3rd party application for this.. i dont want my wall paper to scroll and i want it to fit the whole image
sorry! not aware of any such app..
Alright, but there has to be a specific resolution for the full image to be showed on the screen.. but i think i can make a work around for this.. anyone know the resolution on the stock wallpapers that the SGS has? like the kitten or the flowers wallpaper
ok.. the wallpaper on the homescreen was of great interest to me since that is the thing which you will see a lot! so after reading around forums ive understood the following:
  • The wallpaper will always scroll as long as you have more 1 homescreen. The more the screens the lesser the scroll.
  • if you have one homescreen then it will not scroll but then you will not be able to see the whole wallpaper (try keeping just 1 homescreen and set that kitten wallpaper.. it will smaller than the one in the gallery).. In other words it will be cropped to a smaller size
  • The right resolution for the wallpaper (for 2 or more homescreens) is 960x800
I use just one homescreen so its a bit of a problem to find wallpapers which will look right even after the autocropping problem..
I have 6 home screens, and I make my own wallpaper with resolution 960 x 800. Have always been able to stretch the box to include the whole wallpaper. (Note that the notification bar on top covers up part of the wallpaper.)
Now this is another irritation i feel also. I found no remedy until now. Always u select one wallpaper it will be divided. Selecting one screen doesnt solve this problem. How many wallpapers u will find in the we which has got some meening in every 3 or 4 screens that u use? A good image has got its composition and thats its beauty. Whenever u divide it, certainly u are loosing the appeal. For a panorama photograph it may be good. But then again, this is very much tough to find out pics which can show acceptable composition in all of the splitted screens. Any more ideas?
I'm a bit confused by the whole thing as well.....and I have a photography background, and have been using Imaging software for a long time.
It would seem that an image of 960 x 800 is 960 wide by 800 high. So that would be fine for someone who wants the image to scroll. My question is....What is the best size for an image for a single (non-scrolling) screen??? Is it 480 (wide) x 800 (high)???
Also, does anyone know why the select box for sizing the wallpaper is only HORIZONTAL (landscape)??? With the screen being VERTICAL (portrait) you would think that the select box would allow for a vertical (portrait) image format.
So, on this issue I'm confused....and I suspect many others are as well.
I am going to play with some images and see what I can discover. If anyone out there has already figured this one out...then please chime in. Thx.
I was about to say that scrolling is an option, but maybe it's a LauncherPro option. I like it, so I've never unchecked it. (LP is worth looking into for a lot more than a scrolling option too.)
Hey, u all can try out d app naming multipicture live wallpaper which u can easily find free on android market.
Here is d link 4 it :
https://market.android.com/details?id=org.tamanegi.wallpaper.multipicture
Try out this app, using dis app u can easily set whole image as ur wallpaper.
This app also have many other good setting options to look out for.
Was it helpful to u? If yes then pls let me know.........:)
