Help How to get preloaded lock screen multi-pack from A20 on A12?
Xt1na
just got a galaxy A12, and the preloaded multi-pack lock screen wallpaper is ugly and I hate it.
My A20 came with a dope preloaded multi-pack lock screen wallpaper, but I can't find it anywhere in the galaxy store, I can't find where it's stored in my phone, a couple files were labeled "...wallpaper" ,but it wasn't in there.
I don't know if it's possible to send it to my new phone, I've tried long pressing on it and all that but nothing popped up with sharing option.
Anyone know a way to get the wallpaper pack on my new phone? Or am I stuck with this ugly lock screen wallpaper pack?
It's most likely found within the system apps and might not be accessible to be copied. I found mine on my z fold 3 by going to the phone's settings and under wallpaper, it was there. But I could not copy it or do anything with it other than to chose it as my wallpaper which I do not want to do.
The only thing I can think of doing is to go to your old phone, of you still have it, and set your wallpaper you like and then make a screenshot and use it as your wallpaper on your new phone.
Have you checked Zedge? It's found in the play store. I use it for all of my wallpapers and ringtones........ They have thousands of wallpapers that are pretty slick....... Check it out.
On my phone I get interactive wallpapers, also there is a f-droid apk full of live wallpapers that are really silly :)
