Swollennad
I want to play the new Arnold game thanks
OK the hay Arnold apkDownload it from the play store?
ya but I still would like to try the app that they configured hereDownloading APK files from random sources on the Internet is a really bad idea, they can contain all sorts of nasty things in them. You're safe if you use the Google Play Store though
I have to be rooted to do certain things which I am not and I'm trying to figure out which way to do itYou can open it with a file explorer and clicking trust unknown source. It's not a good idea unless you can verify the source.
