Help HOW TO GO BACK TO ORIGINAL SAMSUNG FIRMWARE AFTER CYANOGEN MOD
So i upgraded my sgs3 GT-I9300 to android 5.0 usinng cyanogen mod,but since it craches so often i now want to go back to the offical samsung jellybean.how do i do that?
First, did you do a full factory reset and wipe caches after flashing CM12? (failure to do so will result in a buggy rom).
If so, to return to stock you'll have to use ODIN (im sure you used that to root etc?) and use it to flash factory firmware found at sammobile.com.
Unless you can find a recovery flashable zip file of stock (you might even find a rooted version).
Or you could just flash cm11 (kitkat), very stable.
Or another lollipop based custom rom (unless you really like Samsung firmware
can you please give me a step by step guide of how to do all these things?
