Root How to go to recovery mode in Galaxy 5
You mean to the original state, like how it was in the shop?
I don't actually know.
But I want that too.
I've the usa Froyo, and it s*cks. No multitouch, no flash, not way faster than eclaire.
I'm gonna download the official Froyo, when it's out in Europe.
my phone changed from I5500 to I5500L. Now Kies doesn't detect my phone as I5500 but as I5500L. help
i dont think there is "command for it"
you have to use apps that helps you get in to it,
multitoch is in progress, not more what i know
to get into recovery mode i use rom manager, (licensed)
then you can choose recovery mode,
and the recoverymode is to install updates trough sd card,
To factory reset-go settings, then Privacy and there is Factory Data Reset.
There is a recovery mode in kies with phone attatched, its called Emergency Firmware Recovery, never used it though.
Rom manager does not detect my phone. When i try to install the mod it displays some other phones, not the galaxy 5.
try connecting the phone to a computer in recovery mode, on the computer install the ADB then type into a command prompt "adb reboot recovery"
