M minisageek Lurker Nov 14, 2009 #1 Hello, is anyone know how to reset Behold II with key combination to hard reset?
kam187 Android Expert Nov 14, 2009 #2 It should be there in the menu, but you can also do it from recovery: Power off the phone Hold down, Volume Down + Call + Hangup When you see the recovery screen press Home to restore.
yatimameiji Android Enthusiast Dec 13, 2009 #4 I figured out that that isnt how to do a hard reset. Once you reach the recovery screen, hit menu. Home+power off brings up more info.
