Root how to increase internal memory
kitbor
Member
guys any suggestion on how to increase internal memory coz I did it last tyme with the one provided by someone in this thread n my fone is not booting up any new suggestion :)
arre simple yar just partition ur mem card with recovery n den just flash d masterminds zip n simply reboot done ! its wrking fr me with zero headaches :)
Flash the INT2EXT+ or INT2EXT+Deodex according to the ROM u r using as INT2EXT+ is for Odex ROMs and INT2EXT+Deodex is for Deodexed ROMs and these zips wont left ur phone with IMEI problems too so these are the best way to have the external memory as internal memory. Reboot twice required after flashing the zip to get it fully configured and become stable.
Use link2SD and move apps, cache, dalvik cache files to SD 2nd partition. Then you can free more internal memory. But need root.
