How to Install Leos 2.0?
silant9
Hi,
Sorry for my question, but my lephone 3gw101 arrived 2days ago and I do not know anything about it. all I know is that the OS version is 1.0, I know it is too old but I do not know how to upgrade it.
I downloaded the file below thanks to this forum but don't know how to install it.
3GW101 version:
ftp://ftp.allphone.com.cn/Lenovo_3GW101_OS2.0_5070_5117.rar
Can someone please tell me step by step how to do it? and is that version the latest?
Thanks and sorry to bother you with questions.
- extract the image folder from the zip file to the root directory of the phones flash card
- pull out the battery and unplug the reboot the phone while holding the right button and just wait.
- release the button when you see the white caracthers on screen.
- remember to delete the image folder from the flash card or you wond be able to flashboot to root your phone.
Then you can install the Google applications, if you wish:
You have 2 methods to install Google apps on LeOS 2.0:
1st one is using a PC and adb commands:
1 - Extract the gapps-hdpi-20101114-signed.zip contents to the ADB folder at your computer (I believe you can copy the ADB files only, you don
Thanks for your immediate replay. I have 2 more questions, could you please kindly help me with.
Is it true that if something goes wrong the mobile will die?
If yes can I take a backup and if something goes wrong I restore it?
Thanks for your kind co operation. I appretiate alot.
Yes, it's a flash process, so if something goes wrong you have a chance to kill your phone.
That's why it's very important to have a fully charged battery, and as a backup I also do the process with the USB cable connected to a notebook, also with a fully charged battery.
Depending on the type of failure, it will be possible or not to restore it, it's unpredictable.
If you can't restore it a Lenovo service center can, but they are located in China.
Anyway I did the process more than 10 times and never had a problem so far.
