how to install viber?
  • Start date Start date
A
Android Question
Guest
hello all,
i want to install viber in my mobile sony ericsson xperia x10. But when i try to install it, it says this application is not supported by android or device. Anybody can help me out to solve this problem.
thx
dharmendra
If you're installing it from the Play store, you should be getting the correct compilation for your phone. If you're installing it from somewhere else, that's probably the problem.
