How to install whatsup
  • Start date Start date
A
Android Question
Guest
I have a Samsung Galaxy sIII mini and would like to install whatsup (like I had in my old blackberry) but been a young 77 years old found difficulty in doing so
Hi and welcome
Hopefully these steps will help:
Set up a google account on your phone if you have not already done so. Normally you are invited to when you first turn it on.
Connect your phone to wifi (or 3G/4G if no wifi)
Open the app drawer by pressing the square of dots at bootom right of the screen
Find the app called Playstore (shopping bag icon with coloured arrow) Press it
Press the magnifying glass search icon at top right
type "whatsapp" into the entry box at the top - select Whatsapp Messenger that should appear in the list below
Press the install button
Press the accept button to allow the app have permission to read your phone data etc
Press the back button several times to exit Playstore
A whatsapp icon should have appeared on your hopepage
Hope this helps
NB There is BBM available for android - search for BBM and install as above. You would be able to use your existing ID and everything should sync automatically - might be better?
Roger
Do you mean "Whatsapp", the socialising app?? If so, log onto this page using your phone browser and click on this link: https://play.google.com/store/apps/details?id=com.whatsapp
OR.... you could click on the attached link, log into the Google Play site using the credentials you use with your phone, and it should automatically be downloaded to your phone (depeinging if you have network/wifi coverage.
Hope this helps.
Hello dude..
Here is the simple answer for your question
simple login to play store with your mobile
search for whats up app
then download and install the whatsup..
instead of whatsup you can use few more apps also those are
We Chat
We Chat is an all in one communications app. Always completely free this app allows easy communication between family and friends across the globe. You can enjoy multimedia messaging, group chats, free voice and video calls all with enhanced privacy(secret).
Line
The Line app offers free calls and messages with absolutely no limits. Line has actually been ranked as the #1 most downloaded app in a massive 52 countries! Communication is enjoyable and convenient and is great to talk to friends or even hold business meetings.
U & Me
U & Me app is said to be the fastest messenger app available for smart phones. Again, there are no limits with this app and if it is speed you want then this download is most definitely for you. You can file share, enjoy group chats generate voice notes, react with instance text and much more.
Instachat
This is the Instagram Messenger Apps. If you simply love to use Instagram and browse photos, search users and tags and privately chatting with your friends and followers, this is the perfect Messenger Apps for
you. Connect with people all over the globe.
