JLSchutt
Member
My Samsung Galaxy Tab S was getting quite short on internal memory (16 GB), while the SD card (64 GB) was almost empty. I went through my list of apps and moved as many of them as I could to the SD card. This freed up a considerable amount of internal memory. However, whenever one of the apps I moved is updated from Google Play, it is once again 100% contained in internal memory. Is there any way to specify that when an app that is on the SD card is updated, the updated version should also go on the SD card? Otherwise it's a nuisance to keep moving apps every time they are updated.
--Jim--
--Jim--
