Root How to keep battery drain minimal during use?
Shuichiro
Hi all! All the advice I get from here is awesome, so I come with a new question. What can I do to minimize battery drain during the time the screen is on?
I've got my phone tweaked to the point where there is only 1% drain every 1-2 hrs., but because I use the phone periodically I keep draining the battery faster than I would like.
I've got the brightness turned all the way down and I don't use widgets. I seems like after an hour of usage I've already killed half the battery. Maybe this is the best I can expect, but I'd rather rule out the other possibilities.
I'm running Dark Minimilist rom at 61-1.3mhz underclocked to 600 on all frequencies on the Interactive governor.
My phone runs pretty well with a max CPU speed of 768mhz....that may help a little. Between this phones poor build quality and the lack of source code/drivers from Moto, I wouldn't expect it to get much better with what you've already done.
The first thing you need to do is check to see what's using all of your battery when you are using it. After using your phone and draining the battery for a while (half way is good)
Go to Settings > Applications > Battery Use
View what is consuming all of your battery. I suspect you may have an application such as google maps running in the background sucking your battery dry.
Find out what is using your battery up, then address the problem.
Good luck.
The battery usage in settings doesn't really reveal anything. It didn't reveal much when I was tweaking the phone. ;)
Can wakelocks affect battery usage even if the phone is achieving deep sleep while the screen is off? Or what about while the screen is on?
