Hello,
I just installed Tasker the other night and am getting the hang of it.
I have Tasker set up to turn on my wifi, bluetooth, audio, etc... when plugged in.
I am having trouble with turning on the screen with Tasker.
I installed the plug-in "Secure Settings" for Tasker and was messing around with the "Wake Device" option.
When I select Wake Device my screen turns on but then dims after a couple of seconds.
-I have a Galaxy Tab 7 with Cyanogenmod 10.1.
-I turned off automatically adjust screen brightness.
-Set Display Timeout to 23h 59m 59s
-I also tried check-marked the option to keep this device on while charging under developer settings.
I just want my screen to be at 100% brightness when charging and never to dim/turn off. How do I do this with the Tasker+Secure Settings plug-in.
Thanks-
Thanks-
